I’m having more problems with my Silverface Deluxe Reverb. I replaced the five filter capacitors and the associated resistors. All seemed well. The amp powered up and played fine with a 5Y3 rectifier tube. I inserted a new 5U4GB rectifier tube and turned on the power. The tube flashed with a white light and I immediately turned it off.
I put the old rectifier tube back in and the amp powered up normally. When I played, however, it sounded raggedy and distorted at low volume. I began looking into things, removed the cover on the filter capacitors and found the inside of covered with a dusting of silver particles. I suspect one or more of the capacitors has failed. I’ve included some pictures below. Does it look like a/some capacitor has failed? Is it possibly related to the rectifier tube fault, or just a coincidence?
Thanks for your help.
