For the umpteenth time I'm replacing a two prong power cord on a friend's amp and it's got me wondering how other folks handle some of the issues that come up with this most common of amp repairs. Feel free to offer any advice on the matter or ask your own questions but the things I'm wondering about specifically are:
The strain relief - Since this never works with the new three prong cord (without modification) what do you usually do? If I can, I cut or grind down the pincher part of the strain relief so the new cord fits. Labor intensive, but more satisifying to keep the old strain relief. I once drilled out the hole to use a larger strain relief. I don't know why but for some reason I felt bad doing this to an old amp. I've also used the rubber grommet with zip ties on either side method. It's the least work but it's not as satisfying and doesn't feel as secure since the cord isn't gripped tightly.
Neutral wire - Do you just splice and heatshrink the neutral wire to the transformer wire and let it float (mechanically speaking) if there's no convenient solder point or do you find a way to add a terminal?
The Death Cap - I have seen amps that either already had the cord replaced or always had a three prong cord that still have a "death cap" from neutral to chassis ground. Should this be removed?
Sorry if these have been covered to death but I didn't see anything.
