It's a newer SVT that has a biasing setup where there are 2 bias pots on the back, each one for three of the six 6550's. Then theres a balance pot. The manual is a no brainer for the bias on each side, but i don't know if theres a way to set the balance. You simply turn the bias pt on each side till the LED just lights. But the balance is to be set as follows from the manual...
Now, i don't have a scope so i wanted to ask if it's ok just to set the balance so the pot is physically in the middle of it's range? I imagine the balance is there so you can balance the 2 sides, then set each side's bias. If thats the case i figure leaving in in the middle and just setting the 2 bias pots should be fine, no? If not, how could i set the balance w/o a scope?
insert a 40Hz signal, adjust the volume control for approximately 25 VRMS output, then adjust the balance control till the LED just lights
