To revive this thread: Can anyone tell me if the Bias spec for a Fender ‘64 Vibroverb AB763 circuit is the same as the ‘64 Vibroverb Custom (reissue) spec (38mA on the 6L6GC PT cathodes at 455 VDC on the plates)? I have the schematics for both, but my AB763 schematic doesn’t specify the bias requirement.
Biasing a '64 Vibroverb Custom
Not trying to be flippant or dismissive, but check post #2! Personally, I think whatever sounds best that doesn't kill tubes or other parts IS best. But you have to do the math. I just leave a tiny bit of wiggle room for myself, frequently aiming on the hotter side. There's a maximum amount lf heat that a tube can dissipate, and anything below "self-destruct" is fair game. Also, both schematics specify +/-20%! That's a pretty wide margin of error.
If you tell us all your measurements and how you're getting them, we CAN help you find out if you're in "safe" range. But whether it's "correct" or not? Anything goes.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Justin, I don't take your response as flippant or dismissive, but I did read post #2. I just was curious as to what the Fender spec was for the AB763 circuit, as a general starting point. By my understanding (and please correct me if I'm wrong), I was under the belief that 70% of max plate dissipation was the general biasing target (or at least one of the methods used for biasing). But with the '64 reissue, if my math is correct, 38 mA produces 17.3 watts at 455 VDC plate voltage, or 57.6% of the max 30 watt plate dissipation, meaning that the Fender spec is kinda cold. Again, if my math is correct, 70% would give you a bias setting of 46 mA. -Just looking to improve my overall understanding of biasing.
Originally posted by ewd View PostJustin, I don't take your response as flippant or dismissive, but I did read post #2. I just was curious as to what the Fender spec was for the AB763 circuit, as a general starting point. By my understanding (and please correct me if I'm wrong), I was under the belief that 70% of max plate dissipation was the general biasing target (or at least one of the methods used for biasing). But with the '64 reissue, if my math is correct, 38 mA produces 17.3 watts at 455 VDC plate voltage, or 57.6% of the max 30 watt plate dissipation, meaning that the Fender spec is kinda cold. Again, if my math is correct, 70% would give you a bias setting of 46 mA. -Just looking to improve my overall understanding of biasing.
You wouldn't typically bias a fixed bias Fender to 46mA per 6L6.
Now that I think of it, somewhere between 30 & 40 seems to be the usual, for the reasons you describe - most 6L6s (I use JJ & SED) don't seem to handle the full 30W. Usually they'll start to redplate after half an hour at about 25W, and I dial them back a little bit more for drift and safety.
Might be where the "70% Rule" came from - knowing the tubes can't handle the claimed dissipation.
Originally posted by Justin Thomas View PostNow that I think of it, somewhere between 30 & 40 seems to be the usual, for the reasons you describe - most 6L6s (I use JJ & SED) don't seem to handle the full 30W. Usually they'll start to redplate after half an hour at about 25W, and I dial them back a little bit more for drift and safety.
Justin
70% of 25W & 70% of 30W are still both "70%" ;-) But this is where there is potentially an issue, you have to know that the tube in question is realistically rated, rather than assume max dissipation.
FWIW Fender only started listing "mA" with regards to bias in the last few years, previously BF P-P 6L6 amp schems just listed voltage and the C- (measured at the junction of the 220K grid loads) would typically be ~11% of the B+. I do believe that biasing by mA is more informative, but if you have a bias pot you may as well go by ear & use the figures to confirm you're not burning anything up. You bias to make the amp sound good principally, then fine tune to ensure realistic part life. Assuming a fixed parameter whether by voltage/%/mA somewhat defeats the object as some tubes in the same amp may have a different sweet spot & some applications require wildly different idle currents.
As Jazz P Bass says, Fenders, especially the fixed bias blonde & brown tolex amps from the early 60's, were biased cooler than today's consensus, especially taking into account lower wall AC. Still go by ear.
