Hi All.
New here :C
I have a VC-50 which has been great for over 5 years but has just started to give some grief with the 2nd channel. Probably my fault, I was a bit rough with it on a small step (about 1 inch drop, I was in a hurry and just pushed it off) I thought about this afterwards and well, yep, idiot.
I'm not sure if that is anything but hey?
I've had valve amps for over 25 years, and I don't beat around my old Marshalls. I guess I took her for granted and now I'm sorry.
Anyway, the level from the 2nd channel (Channel A, dirty) is almost non existent. You can just hear sounds like it's turned right down, though it's on 10. (It's a Laney, doesn't go to 11)
I've swapped out all the 12ax7s in the amp to no avail. I'm about to start going over the schems when I thought I'd see if anybody else might have some ideas.
My thoughts: Obviously the power section is fine. I believe the pots are fine, coz when I turn them down the little bit of noise goes away altogether, The relay seems to be operating, but perhaps there's an issue with the contacts in it? I've just got to go over the signal chain of that section of the pre amp!
BTW, I am an electrician, which means I don't know much about electronics, though I should be able to not do the funky chicken with this.
All help gratefully accepted.
Thanks.
Dronno.
New here :C
Thanks.
Dronno.
