I've got a project amp that I've been working on out of a silverface vibrolux reverb, and I decided to improve upon the old grounding system in the amp and came up with one that was as star grounded as I could get, and in the process I decided to also move the totem pole e-cap stack from under the cap can to inside of the amp to reduce wire length some and so I could separate more stages from one another and prevent crosstalk. After I implemented the new system the amp started making a swelling noise and then a thump with the volume on zero after the standby switch was thrown.
The amp can pick up guitar signal and the signal will swell and then 'thump' back to no volume and start to swell again etc. I've gone back piece by piece and undone the entire grounding system I had initially developed and reverted back to the original power supply format and I still get the same problem now. I've replaced the rectifier tube with other known good rectifier tubes, I've re-tensioned the rectifier tube sockets, I've replaced power tubes with known good power tubes.
The only step I haven't taken yet aside from checking a transformer is replacing the filter caps. I've also noticed that every 'thump' generally either creates a bright blue light, tiny spark, or usually combination of the two inside one of both of the power tubes. The thumping never takes place until the standby is thrown, but sparking inside the tubes leaves me to believe that the problem may lie with one of the transformers, and I'm not sure which it would be, but I have a feeling that since bad things only happen once the standby is thrown that it's probably the output transformer.
A related question that I have is: Do transformers have a limit on how much capacitance they can handle? I assume that something I did during the process of the grounding scheme and power supply rework caused this problem, and that seems to be the only conclusion I was able to come up with that would lead to my amp continuing to behave this way.
Any help on what my be the root of this problem would be greatly appreciated.
