Hi I am trying to install a reverb tank in my amp there are 4 prongs coming from the amp but I don't have the proper plug and im not sure where what wire goes where any advice??
Peavey Nashville 400 reverb tank
COntact peavey customer service for the schematic. it will include parts layout. You can ask PV parts if they have wire harness for the reverb for this era model. Or just call it the reverb cable assembly.
The four pins will fit into a "Molex" connector, which will have the two cables running down to the reverb pan. The Molex is in the "09" series FOur female pins in a four pin plastic shell. You could make one yourself. You COULD solder wires directly to the four pins, but I advise against that. You might want to pull the board out one day.
Pan will be a 4EB2C1B type (or 9EB... )Education is what you're left with after you have forgotten what you have learned.
