Hot rod deville 4 10 combo
  • Hot rod deville 4 10 combo
    When i use the overdrive it switches back and forth between the clean channel.
    Although when I use the clean channel its fine. Any suggestions? Please help I have a big show coming up and i need it fixed asap!!
    Could be as simple as dirt in the jack. It could be as complicated as fluctuating voltages in the low V rail or similar. If I were inexperienced, and had a show coming up, I would get it into a shop soon. Most fix it yourself projects run longer than shop repairs. What test equipement do you own?
      Same old same old.
      My take on the problem.
      The big cement power resistors on the main board need to be resoldered.
        Same old same old.
        I'll see that diagnosis and raise:
        Everything in that amp bigger than a 1/2W resistor needs to be resoldered.
        My rants, products, services and incoherent babblings on my blog.
        casibom betturkey
