I'm working on this JCM900 2502 combo and I'm only getting 36 Watts RMS out of it. The tubes are new and biased properly, but it's only putting out 72% of what it should. I've fed it thru the receive jack and it's still low. I'm running EL34's in it. It used to have 6L6's, but I changed a bias resistor to get the bias voltage correct.
I've done the following:
1. Tried other tubes.
2. Checked the OT out of circuit.
3. Swapped in another OT.
4. Screens are ok. 2.2Kohm as standard. Grids are 1.5Kohm, with a 2.2Kohm added in series on one side?
5. Tube voltages look reasonable.
6. Triode/Pentode switch cuts power as expected.
7. Tried it with 6L6's too.
The plates are sitting at 440V at idle and drop to 398V at clipping. I think that's reasonable.
Filter caps are original, but the output is not exhibiting any 120Hz or 60Hz hum.
What am I missing? What else could cause this?
Thanks in advance!
Thanks in advance!
