I've just done a little work on a Deluxe Reverb Reissue, and I noticed that the reverb is pretty noisy. The owner doesn't really use reverb much, so he didn't want me to spend a lot of time working on it.
The major problem was a bad RCA connector at the output of the reverb tank, but even after replacing that cable, there's a buzz that increases with the reverb volume setting. From the sound, it has to be a grounding issue, but the main amp chassis and reverb tank body are connected via the return cable shield. And the reverb drive cable is isolated from ground at the tank, so there doesn't appear to be a loop.
With the reverb tank disconnected, the buzz disappears. It's not the reverb recovery AX7.
Is this just a noisy reverb circuit, or is there something I haven't found?
