Hello folks,
I've been "restoring" a 69 silverface bandmaster reverb for a little bit now; when it came to me it had no reverb tank, no tubes, and a host of leaky caps. All of which I have taken care of, but it has one lingering problem that I can't nail down:
When I first fire it up, the vibe channel passes no signal. I can hear the ticking of the vibe, and the reverb will rattle, but no signal through. With the volume up after a minute or two, some staticy crackle starts coming through, when the crackle is gone, the vibe channel works fine. And it seems like it would keep on working too, I've played for about 20 minutes or so, and the signal never cuts out.
I've chopsticked the dickens out of the vibe section; when I redid the power section cap, I also replaced all of the ceramics and electrolytics on the board, as well as one of the film caps that looked dodgy (there was a lot of corrosion around one of the legs).
Any ideas as to how I should proceed with the debugging?
