Wax leaking from PT troubleshooting help
  • Wax leaking from PT troubleshooting help
    I used a PT from a Hammond organ reverb amp in a build and in the amps first outing it started leaking wax from the primary and secondary windings. This seems to be a problem and I plan to replace the tranny. But before I do I need to troubleshoot the cause. Any help is appreciated.
    Never mind, I failed to hook up the to ground but since I wired the amp in a pre-existing fixed bias amp, it worked, but not properly baised. Just corrected and amp is working perfectly.
      Glad we could help.
        Glad we could help.
        johnk
        JohnK Custom Basses
