Hey all. I bought a brand new Fender Frontman 212R about 2 years ago. For about the last 2 weeks, it's been making this crackling noise then a sudden and loud POP (very loud). I've switched guitars and cables and the result is the same. Can anyone offer up any advice for me? Thank you in advance.
Fender Frontman 212R Popping/Crackling
Yes, use your 5 year warranty, and let Fender fix it. Find the authorized Fender shop closest to yiou and take it there, along with "proof of purchase."
Try this, ball up your fist and whack the top of the amp. Does that cause it to make the sounds? If so, ther is a loose connection inside.
And as a tech, the first thing I suspect inside is cracked solder to the main filter caps.Education is what you're left with after you have forgotten what you have learned.
