The VHT Special 6, and Special 6 Ultra is a Single ended Amp that comes with a 6V6 Power Tube.
VHT advertises that the amp can be ran with other Power Tubes.
It has a built in Eyelet, or Turret type Component Board.
They say you can try 6L6 EL34s and Others.
The problem is the Heater Circuit has an internal Fuse that several have complained about blowing if you go to a larger tube like the EL34.
VHT Says to change out the 4 Amp with a 6 Amp Slow Blow heater fuse.
It appears this Fuse is soldered to the Circuit Board.
For an Amp Supposedly Designed to Mod, the Soldered Internal Heater Fuse Seems like a terrible way to go about things.
So now you have Un-Qualified Guitar Players needing to get in the amp and solder a new fuse to the board.
Any Ideas on this, and have Others ran across this problem.
Like I said earlier Guys are buying this amp with the intent to try different tubes.
Thanks,
Terry
Thanks,
Terry
