I recently repaired the power supply on an ART SLA1 studio amplifier (shorted power transformer, of all things) and am having trouble with the protection relay on Channel 2.
SLA1.pdfSLA1.pdf
When I power the amp on, the relays are supposed to click "on" after a second or two. Channel 1 works as it should. Channel 2's relay will not click on unless I flick it or tap it. It takes almost no force at all. But once it's "on," Channel 2 works normally as well. What's throwing me off is that all the voltages I'm reading seem to be right (and match those on Channel 1).
Voltages:
28 VDC @ cathode D6
14 VDC @ anode D6
0.72 VDC @ pin 6 U4
I have replaced the relay RY2 as well as D6. R61 reads 14.27k (close enough to 15k). Should I suspect U4 or Q20? Is it possible that, despite the voltages being correct, U4 isn't sourcing the current the relay needs? Any other suggestions?
SLA1.pdfSLA1.pdf
Voltages:
28 VDC @ cathode D6
14 VDC @ anode D6
0.72 VDC @ pin 6 U4
