Old Fender Frontman 25R MIM problem
  • Old Fender Frontman 25R MIM problem
    Hello Fellas
    I just bought a old fender Frontman 25R that has the black metal grill in the front, made in Mexico. Not the newer one. I noticed it pops real loud when I turn it off. My daughter has the exact same model and hers seem to have a delay turn on and off and does not make that sound when turning on and off.
    The circuit looks real simple and the only thing I could think of was the power output chip that might be not doing the delay on and off. The amp works but I wonder how long before poof...
    any suggestions?
    Thanks
    Many many many amps pop when you turn them off. I don't consider it a problem. ANy pop is no louder than the peak audio it can produce.
    Does it make a difference if you turn the reverb all the way down before hitting the power switch?
    Perhaps your power switch is a little more arc-y that hers.
    These amps don't have delay circuits.
      Hey Enzo,
      Well,
      My daughters amp has the TDA1514A output chip 9 pin and suprisingly seems to delay audio on and off for for a brief moment when turning off or on. no pops at all and hers is a 2000 model
      The other amp has a 1992 board and a different NEC 12 pin chip that is a uPC1188H in it.
      No difference with the reverb on or off. If the amp is in clean channel mode and you turn it off it switches to distortion mode for a brief moment too. My daghters amp does not do that either.
      Looks like the circuit in both amps are almost the same accept the output chip.
      Thanks
      Slo
        Is the pop the only thing your hearing wrong with the amp? My old (about 20years) Fender 85 (SS) amp pops at turn off too, but otherwise it's always worked fine. I dont consider the pop a defect.
        - Yogi Berra
          Different circuit, different parts, they perform different. I still don;t see it as needing repair.
