A friend brought by an old crate head, wanted to see if I could fix it. It is blowing fuses. He said he plugs it in, it hums for a few seconds, and then pops the fuse. He recently had the amp in the shop recently to replace 2 switches on the front panel (those small push switches, one is a channel switch and the other is for the chorus). It started popping fuses after he had the work done. Obviously it passed the tech's QA, though, so it would seem that it worked OK at some point after the servicing was done.
Since it was blowing fuses, I figured I'd start at the power supply first. I unhooked the power transformer and verified that it is outputting voltage. The filter caps are rated for 50v, and I got 60vac on the PT secondaries. I figured that sounded about right, since after rectification that should be ~ 43vdc. I checked the rectifier diodes, and they are all right too.
I told him to get some more fuses (his last one was blown, so there was only so much diagnosis I could do) and to order some new filter caps (they aren't too expensive on this amp). The amp is about 15 years old, and I figured filter caps might be at fault because I had nothing else really to go on.
So, now what? I don't know much about SS amps. So how should I troubleshoot this? It's not like I can pull tubes. Did I take the right approach in starting from the power supply, given the circumstances?
