This amp has an annoying hum when the reverb is on. I've narrowed it down to a certain area but cannot figure out what to do. If I disconnect the .001 coupling cap from the plate of V4 (reverb recovery) there's still the hum. Oh and the hum is low, like 60hz. I then grounded the bottom of the 470k and the hum is gone. I checked the DC resistance of V2 pin 5 grid to ground and it's ~500k when the reverb is on. So the grid DOES have a ground path when the reverb is on.
So I'm confused here because with the .001 coupling cap disconnected there's still hum. This would tell me that the source of the hum is after that cap.
On the other hand, grounding the 470k (thus reducing the overall value of the grid leak path for V2) gets rid of the hum... so where the heck is this coming from??
