I am working on a VOX Essex Bass with a loud hum. First thing I did was check the chassis to earth ground using a volt meter and I measured 120VAC. The death cap is alive and well in this thing.
I want to rewire the primary side of the amplifier and remove the line reverse switch and cap, then add a three prong power cord. I think I've got the unit wired correctly but was hoping I could get a confirmation from others that I have wired the amp correctly using the 3 prong plug. I've never done this on an old amp like this so I'm a little apprehensive to flip the power switch on without someone else giving me the reassurance that it is wired right. I traced the primary and secondary side of the amp and drew it in ORCAD. Please give me a thumbs up if you agree with my rewire.
Just to provide a little more info, the electrolytic caps in this things are all leaking. I have replaced all of them in the power supply section.
Thanks!!
Thanks!!
