Interesting Russian amp
I see a lot of different amps from the 80s and early 90s, not too many from the 70s however. I have not seen this one but generally they came in two general types: Really over built and way underbuilt junk. Nice lacing. All those semiconductors are still available here and are really cheap compared to the imports. I see a lot of units with high voltage Teflon dielectric capacitors that perform beautifully in higher end of the voltage spectrum tube circuits. One came to me, running a pair of 6п3с-е with only 300 volts on the plates but all the caps were 1500 rating. The transformer had a lot of iron in it for a 25 watt amp.
Is there a name on it anywhere? I can probably find a print for it.
By the way, the markings on the preamp are НЧ СЧ ВЧ are LF, MF and HF respectively.
Most people assume that Russian or Soviet technology was way behind but in many areas such as ultra high voltage they were quite ahead of the rest of the world. They had a well developed semiconductor industry and even microprocessors from early on. The heavy industrial and military gear is very sophisticated but the consumer radios, hi-fi and tvs were pretty crude. It was like an alternative universe people in the west did not know really existed. Many cities have permanent outdoor Radio flea markets so builders and experimenters can exchange, buy, sell or just talk about parts.
Originally posted by km6xz View PostI see a lot of different amps from the 80s and early 90s, not too many from the 70s however.
Originally posted by km6xz View PostI have not seen this one but generally they came in two general types: Really over built and way underbuilt junk.
Originally posted by km6xz View PostIs there a name on it anywhere? I can probably find a print for it.
Originally posted by km6xz View PostBy the way, the markings on the preamp are НЧ СЧ ВЧ are LF, MF and HF respectively.
Originally posted by km6xz View PostMost people assume that Russian or Soviet technology was way behind but in many areas such as ultra high voltage they were quite ahead of the rest of the world.
Mark
The speaker says 1990-07(July or 7th week of 1990?) on the label, but it could've been replaced. The 47K potentiometers here look built as a tank: http://music-electronics-forum.com/a...779741-pre.jpg
Awesome stuff, thanks for sharing.
Ah, those are 47k pots, I thought they were Russian military grade op-amps.
Here's a particularly scary one, a Tesla coil powered by a GMI-38 radar modulator tube, a Winged-C one no less.
4hv.org: Forums / Tesla Coils / Big Pulsed Vacuum Tube Tesla Coil GMI-38
I heard Russian TVs came supplied with a fire extinguisher."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
There's some interesting Russian analog synths from the 80s as well.
Russian synth'sThe farmer takes a wife, the barber takes a pole....
I do not know what that part is because only part of the number is showing. It could be a version of the КР574УД1А which is a common single channel jFET low noise opamp of the era. It is available here but is similar to the AD513 in the west. A lot of the opamps made here had max rails of 10v but that one is 15v so it would be a good candidate. Any general purpose jFET input opamp would probably work well.
That one is entirely FET topography, not just the input.
Thanks everyone for help (especially to km6xz). Unfortunately the owner of the amp decided not to fix the amp because he can buy a chinesse amp for similar amount of money (~$100). It's a pitty because the amp didn't seem difficult to be fixed. And it looked like fancy "military" version - most probably could be use for many years more after being fixed.
Mark
