anyone know what size fuses these are?
bugera 1990
Agreed.
They appear to be "ceramic" fuses, 5 x 20mm (width & length), hense the cloudy look.
Ceramic fuses help to contain any "flash" when they are overstressed.
FYI: The fuses are labeled :
-F2A: this a "fast acting" 2 amp fuse.
-T1A: this is a "slow blow" (ie: time delay) 1 amp fuse.
Please note that the fuses have a "voltage rating" of 250 volts.
As this is what is installed from the factory, I would recommend that this rating is observed, when purchasing replacement fuses.Last edited by Jazz P Bass; 11-11-2011, 03:50 PM.
thanks guys!
looks like a t1ah for some reason is that a 1 amp timed or a 10?Last edited by powertuber; 11-11-2011, 03:42 PM.
yes i found 2 took them out shook them they make a sound like a burnt out light bulb.
got some cheap sovtec tubes for now ill put in there
6L6GC 30 watts max
480 Volts
70%
43.75 ma bias @
does that sound about right?Last edited by powertuber; 11-11-2011, 07:51 PM.
