This amp was delivered to me with low volume. I was told it worked great until a Torres mod was performed on it and now the volume is low.
What I do not know is what does the Torres mod do to the amp? The attached photo highlights two caps that I was told were replaced. I have highlighted a few resistors because these values are way off from what the AB165 schematic said they should be. I understand that resistors may not be exactly what is on the schematic, but I highlighted the ones I thought didn't jive or even come close. INcidently, the photo is a snap shot of the circuit at the 12AT7.
The voltage value at pin 1 of the 12AT7 is 450v, the schemo lists it as 225v? The voltage at pins 3 and 8 of the 12AT7 is like 18v. The schemo lists it as 102v, but in the photo the value of the resistor that is missing is 470k, the schemo lists it as 470... for the Torres mod, is it supposed to be 470k??? I was about to replace this resistor with a 470 but I thought I should ask if the Torres mod changes this resistor to 470k?
Link to Bassman Ab165 schematic
