Hi - I'm trying to get the trem circuit working on an early master volume (non-pp) twin reverb. All electrolytics have been replaced
but the feedback caps have not. The bug flashes and all voltages are about right on V5. Intensity pot resistance checks out, speed pot affects the bug properly. Everything else about the channel seems fine just no sign of tremolo (other than ticking)
The voltage varies from about 300v-150v on pin 1 of v5 with the trem jack grounded. Can I assume that the feedback caps are good if this is the case? The resistors check out except for the 2.2 meg at the bias supply - that measures about 1.3 megs (in the circuit)
I have very little experience with these circuits - where else should I be looking for problems?
Thanks.
Thanks.
