Hi Y'all,
This is my 1st thread on this forum! I have a Line 6 Flextone XL that is currently having major issues with its Line 6 Floorboard counterpart. The Floorboard I'm using is the Line 6-99 Floorboard with 2 expression pedals.(Line 6 Floorboard Controller Pedal at zZounds) The pedal is functionoing but the indicator lights that corespond to what function you are on and what bank you are using are not working. The LED bank indicator constaly displays "888" and also "886,..-, etc. I have spoke to line 6 and they narrowed the problem down from the ethernet cable(tried about 5 same issue) to the connection on the back of the amp a rj-45 ethernet type connector and said that one of the pins is not working or sending info to the wrong one. My question is has anyone experience this issue with this amp or any line 6 models and is the remedy in replacing the ethernet jack or is it something of a greater issuse such as the PCB?
