hi forumites, can anybody shed any light on a problem i am having with a jcm900 hi gain dual reverb model 4501 please>
all voltages measure fine on all tubes, there are no obvious blown components, i get sound but it's quite a low volume. almost like the amp is stuck on low power setting,the high/low power switch doesnt seem to affect anything, i have replaced that switch.
r37 was open so i replaced that. there doesnt seem to be much in the half power circuit so i am now starting to wonder if that part of the circuit is working fine.
i have used another amplifier with the send and return to isolate the problem to the power amp section of the amp (the pre-amp works fine).
i have cleaned and checked the send/return sockets as they can cause problems.
i have substituted valves just in case some where bad but all voltages read fine.
bias is all good.
i cant think what else in the power amp section would reduce volume.
the output transformer has been tested fine.
it's annoying me as i am running out of parts to test and i just dont believe in gremlins!
anybody got any ideas?
i am just about to check wether some idiot has put el34's in an amp that was set up for 5881's but i have been told that it's run fine on el34's for years, i do know some of them had 5881's tho!
bias is all good.
