This is my first Prosonic repair, appreciate any help.
First of all, the amp sounds great. Good tone, no buzz etc. Tubes checked/replaced and voltages are clean. The only evident mod I see is someone put an impedance selector in, to select 4-8-16 ohms. Their work looks clean and functional. I believe its also had the service tech channel switching mod done (per elsewhere in this forum) as I do not have any noticable noise when switching from normal to drive on the front panel.
However, on the normal channel:
When the volume is turned up, but no master volume, you get sound if Gain 2 happens to be turned up, (if you turn all three tone knobs off, the sound goes away) If Gain 2 is off the master volume works as it should and eliminates all sound when turned off.
Also there is a weak Treble response, sound volume doesn't increase with treble increase but it does "hollow out" the bass and mid tones.
On the drive channel:
With the volume turned up, but no master volume you get sound if gain 1 or gain 2 are turned up.
Treble response is the same as above.
I don't have another Prosonic to compare agains't. Is this a quirky design flaw or do I have (separate/related) circuit issues?
Hopefully you can follow the above, any thoughts?
