First post here by a newbie in amp repair...
Anyway, I bought a Peavey SC212 amp that had some intermittent loud humming problems. A look inside and some internet searching pointed to the two burnt looking power transistors as the problem. I just replaced all eight transistors and would like to test it with my multimeter before plugging it in and turning it on.
When I test one of these transistors NOT installed on the board with the diode check, things make sense and agree with the instructions you find on the internet for testing.
When I try to test the finished, installed transistors, it seems like it conducts in both directions. Also, using the ohmmeter test, there's a closed circuit between just about everything. Is this normal now that the circuit board is in play? Should the plastic gasket between the transistor and rail insulate them?
Are there any ways to test this better?
TIA.
TIA.
