vox tube change
  • vox tube change
    Hey Guys,
    Just wanted to check before i wrecked something beautiful,
    Seen the AC-30's are cathode biased you can simply unplug and change the EL84 power tubes, right?
    Thanks
    Originally posted by Yobleduwop View Post
    Hey Guys,
    Thanks
    Yes. But your amp and your ears will appreciate you installing a quad balanced set of EL84's available from all reputable suppliers. I did one last week with JJ Tesla valves. It sounded bloody luvly.
    Peter.
      Thats exactly the quad i bought, using it for recording so hopefully it pays off
        Is it possible to only put 2 tubes in a EL84? to theorleticly get half power?
        Thanks Joel
          Thanks Joel
          Not really,
          The primary impedance of your output transformer is designed to match your 4 output valves. There is a thread or 2 on this forum which goes into this question in some detail.
          Personally, I've never really understood why anyone would want to do this with an AC30. Unless of course you're trying to replicate an AC15. If so........ Get an AC15 and dont devalue your AC30.
            Thanks Joel
            No. The remaining tubes would draw way too much current through the cathode resistor and melt down.
            And of course what Peter said.
            Best regards,
            Albert
            www.albertkreuzer.com
            casibom betturkey
