I've got an amp that makes weird noises fairly regularly. I've attatched a clip since it's a little hard to describe, but if I were to describe it I'd say it's sort if a squeeky, staticy thing. The amp is a solid state Silvertone 1465.
-None of the controls seem to affect the sound.
-Did the chopstick thing, several times, no effect
-I replaced all the electrolytic caps on a whim. Didn't change anything.
-Bringing the amp up on a variac after recapping, I noticed the noise gets a lot worse when the voltage is a little low. 80-90V really gets it going. This is what I did to make the clip since the noise is too sporadic otherwise.
-I posted clips a couple years ago of a freinds wurlitzer electric piano a few years back that was making similar noises. It was suggested by someone that it sounded like RF interference. Could that be what's going on? My only other guess is internal arcing in a component, hopefully not the output transformer.
