B-100R...got it, turned it on, loud current drawing hum sound..no signal output.
pull the output transistors and start from AC checking voltage supply, rectifier, filter caps..replace Qs 3-9
C2 C3, check diodes, resistors, replaced IC1 and 2...getting the 16v, 20v and 40v (within 10%), used a current limiter to re-power up and all is well...connect direct to outlet, play for a good hour and reasonable volume but turning upto about 6 on the MV and pop goes the fuse. OP transistors shorted. Speaker sounds fine..honestly I have not taken enough time to really learn transistor circuits as I have with tubes...measuring output current on tube amps often helps me find the problem...any ideas...thanks in advance.
