The Zener voltage dropping diode can be either in the ground leg of the bridge as Doug shows or the hot lead before the input capacitors.
The center tap of the transformer is unrelated to the Zener position and is connected to the junction between the first two capacitors because you get about 20db less ripple by connecting there. It is optional but recommended for this reason. Don't hook it up to ground!!!
There is no voltage doubling with this circuit. Of course, you do double the voltage capability of the two input capacitors by connecting them in series.
