This is a newer model Cube 60. There's no sound from the main speaker, but the Line Out, Tuner Out, and Headphone out all work. I'm still looking for a schematic, the one I have is the older model with preamp in/out. Are there any common problems with these? Power transistors?
Roland Cube 60 No Output
So test the speaker, inspect the speaker wiring. Headphones jacks usually cut out the speaker, so look at the phones jack for a cutout contact not closing.Education is what you're left with after you have forgotten what you have learned.
various cube & blues cube schematics
On the blues cube schematic, there seems to be a fet in to the power amp, presumably as a mute.
If this was permanently "off", you woudl get no sound from the speaker, but the preamp outs would all be ok.
But as Enzo says, check the speaker voice coil resistance, & plug a lead from preamp out socket to power amp in socket, if there is one
Thanks for the schematics!
