fender hot rod deluxe from '98.
it kind of works... it passes a signal and the tone controls do their thing but the output is VERY low volume
and it's quite distorted.
i ran a cable from the pre-amp out jack and it sounded fine. i then tried the power amp in jack and still had
the bad sound. so, i figure the problem is in the power amp.
voltages on power tube sockets w/ tubes pulled are Pin 3: 475v, pin 4: 475v, pin 5: -48v
according to the schematic, pin 4 is a little high. pin 3 seems to be VERY high and pin 5 seems normal.
i lifted the grounded end of one of the R3000 diodes off of pin 3 and measured using the diode function of my multimeter.
i would've thought they should measure at about .5v each, but the one that i lifted measures @ 1.5v, while the one still in place
measures @ 1v. i get 0v when i try to measure CR3 (1n5062).
what else could be causing pin 3 to measure so high? did the OT go bad?
