i just received my marshall 2555 that i won on ebay to replace the 2553 i had stolen from me last november.
the first thing i did was to dial in the settings i'd been using for almost 2 decades and give it a try.
VERY disappointed! the preamp overdrive was weak and thin. i popped in some EH preamp tubes that i had used in my old 2553, but it barely increased the gain.
so i opened it up to see if there was any obvious mods, like bypassing the clipping diodes & LEDs. but it looks pretty clean to me. but i'm just going by the ugly mods i've performed in the past.
while i had it open, i went ahead and checked the power tube bias. it was at 25ma. so i thought i'd do a quick bump to 35...but the bias pot was maxed out!
i even tried a new set of jje34ls w/ the same results. the bias resistor is 56k, but a schem i found says it should be 47k.
any ideas?
does cold bias on the power tube affect the preamp tubes?
pin3=430volts
here's some pics (click for larger versions):
thanks,
-mike
any ideas?
pin3=430volts
thanks,
-mike
