I am repairing a Peavey Supreme XL with a broken reverb that has the little digital reverb board. The board is getting signal, and the 5 volt power supply on the board is ok, so I suspect the chip is faulty. However, since this is a microprocessor, I wonder - is there any way to "reboot" it that might cure the problem?
Peavey Digital Reverb
Originally posted by Billy R aka DynaFreak View PostI am definitely going to order the entire board, I have no desire to get into repairing it, I was just curious about the possibility of resetting it somehow.
Originally posted by Billy R aka DynaFreak View Postcan you tell me exactly what they mean by "asserted"?
So if you can locate the datasheet for the main DSP chip and find the reset pin, you can watch that pin on power up with a scope and see if it changes states (it will do this quite fast) from low to hi (or the inverse). The datasheet should specify what state the reset line should be in for a reset condition. "Res" or "Reset" with a line over the top of the term means that line is active low, so if it was stuck in reset, that line would remain low. The absence of the line over the term indicates active high. So, if the reset is active low, the reset line should start low (0v) and jump up to high (5v). The datasheet will tell you how long the reset period should be, measured in mS.
You can force a reset just to see if it runs with a manual reset. If the reset is high for run, use a 1k resistor and a clip lead to gnd. Power it up, touch the reset pin (or something connected too it) briefly and see if it makes the DSP run. If not, its likely hosed or has severed solder connections.The farmer takes a wife, the barber takes a pole....
Great thread, you all have answered my basic question, now I have another: how does the chip, which is a multifunction effects processor, know to be a reverb only? I read the datasheet, so please dont quote that. I understand that there is a boot sequence that most likely is involved, but is the chip itself "pre-programmed" using some external connected device prior to being installed in the amp?
Originally posted by Billy R aka DynaFreak View PostGreat thread, you all have answered my basic question, now I have another: how does the chip, which is a multifunction effects processor, know to be a reverb only? I read the datasheet, so please dont quote that. I understand that there is a boot sequence that most likely is involved, but is the chip itself "pre-programmed" using some external connected device prior to being installed in the amp?
Page 1: Header: Fixed Function Multi-Effects Audio Processor
Features: Audio Processor for embedded reverb/effects applications.
- Firmware for the CS4811 is provided by Cirrus Logic.
There are two different firmware codes available; one for
guitar effects and one for audio mixers. The guitar effects
firmware provides a host of electric guitar effects including
spring reverb, delay, chorus, flange and tremolo.
The mixer effects firmware provides a suite of effects
such as digital reverb, delay and chorus which are suitable
for use in audio mixers, karaoke and acoustic
instrument amplifiers.
So apparently the IC runs two different firmware versions, provided by Cirrus Logic.
Link: CS4811 pdf, CS4811 description, CS4811 datasheets, CS4811 view ::: ALLDATASHEET :::
Yes, I read your post.
Sorry, I missed the part about "don't quote the datasheet".
The question that I thought you asked was " how does the chip, which is a multifunction effects processor, know to be a reverb only?"
The firmware < according to the datasheet (oops, I quoted it) is loaded from an EEprom.
"A serial control port allows the device to boot firmware from a compact and low cost SPI or I2C serial EEPROM."
Where that is on the PCB board I do not know.
How does a multieffect IC know to be just a reverb? How does a guitar know to play only the E and A strings? How does a piano know to play only middle C? More to the point, how does your computer know to come to this web site instead of Fender's? Like anything else, the IC has control inputs, it does what you instruct it to do.
Belton makes a multieffect IC. I often think how easy it would be to make a line of various single effect pedals, all using the same stupid IC. Just wire each one up to enable the different effects.
DOn't confuse reset (a simple action that makes sure the programming starts at the start each time it is powered up), with restoring factory setting or reinitialization. ANy microprocessor will have a power-on reset function. A basic little circuit that sends a reset pulse to the IC a moment after power is applied. All it does is start the program at step 1.
ANy computer device that has alterable memory - like latches and presets that are editable - also has the possibility that it will have that memory corrupted. I recall one synth that liked to decide now and then to put maximum vibrato on every patch. You'd have to to a factory reset - a reinitialization - to clear that. That is not the same as the power up reset. That is not the function of the reset pin on the IC. In fact, even with scrambled memory, that reset happens each time you power up. Just that in that case, the program starts at step 1 but with still scrambled memory.
If I read the schematic correctly, the instructions for this particular effect are in U1, the EPROM.Education is what you're left with after you have forgotten what you have learned.
