I have a Maverick that only puts out very low volume UNLESS a jumper cable is plugged into the fx send jack. When plugged into this jack the amp's LEAD channel works great, sound great, shows no isuues, however the rhythm channel still barely outputs any volume at all. It doesn't matter whether the fx send/return jacks are connected or the patch cord is just left dangling from the send jack.
All voltages on the tubes test ok or at least very close to the schematic.
I can see two of the relays actuate when the lead/rhythm because someone has exposed the inside of the relays.
The fx mix potentiometer works fine/tests ok.
Thanks for any help in advance. Pic and schematic attached.
