I had a 135w Fender Twin recently with the tank missing but luckily an empty bag remained.
Thought I'd take a punt and try the mod tank equivalent.
I pulled the rubber stoppers off and taped the standard issue piece of cardboard across the bottom.
After fitting, with master vol full and reverb vol about 5 it would develop acoustic feedback about C# above middle C !
I tried all manner of tightening/loosening the bag and rearranging the leads to no avail.
So I pulled the tank and re-arranged the 4 suspension springs to make it sloppier (ie not so taut)
although the reverb springs were nearly touching the bottom cardboard there was still clearance.
Then I wrapped the tank in thin foam and with the help of a partner in crime forced the whole lot
back in the bag (yes the stitching held up) .
Bingo no feedback!
The tone seemed to me a little more mid-rangey than I remembered from the Accutronics but had no
original tank to A/B compare it.
I suspect the two Celestions fitted may have also contributed to the midrange which exacerbated
the feedback problem.
However there was more than enough reverb to drown in and I doubt the owner would ever have the
reverb vol above 3.
Bingo no feedback!
reverb vol above 3.
