I would take all the tubes out or at least the power tubes. On the power tube sockets before you power it up ohm out pin 9 of one side to pin 9 of the other side to get 200 ohms of screen resistance. The after you power it up saying the 1 amp fuse doesn't blow again you should get as follows.
Pin 7 = @ 300 + volts
Pin 2 = negative -15 volts
Pin 3 = Zero
Pin 9 = @ 295 + volts
The heaters I believe are in series so they either all work or none. So if you put all the tubes in and they light the heaters are ok.
Pin 3 = Zero
