Got another one in here. I fixed one previously on this thread: http://music-electronics-forum.com/t24636/
This one has no speaker output too. This one however seems to be in shutdown mode. I know this because the signal stops at the input to U18A. I believe that the Vactrol U23 controls this with all the other shutdown components... ie Q18. Also the mosfet driver ICs both have 0v on CSD pin 2 which tells me that Q33 is saturated... which is controlled by the shutdown circuitry related to U3. This means the driver ICs are OFF.
U300
pin13: -2vDC
pin15: 3vDC
U17
pin13: 300mvDC
pin15: 19v
So it seems there's something not right about the -2vDC and 3v measurement on the top side of the PA. I've tested the mosfets and don't see anything wrong as I get identical measurements from one side of the PA to the other. Can mosfets be tested like bjt's?
Not quite sure what to look for here. Any advice?
U300
pin13: -2vDC
pin15: 3vDC
U17
pin13: 300mvDC
pin15: 19v
