Hey guys,
I have a problem with my first ever tube amp. I bought my Marshall JTM 610 with extra 112 cabinet from the first owner. He never played it loud, but also never changed the tubes.
I have never had problems with it, until about 3 months ago my volume started to drop. A lot of jtm60s seem to be having problems with heat, but when I opened the amp there were absolutely no signs of heat damage. I did notice a blue glow coming from one of the power tubes when i played.
I tried plugging a short lead between the effects loop in and out but with no effect.
So eventually I brought the amp to my local music store. He checked all the wiring, all the solder joints and replaced the El-34 powertubes and one transistor which he thought was bad.
Well all of this didn't fix the problem of the volume drop. but something changed about the volume drop. I noticed that the volume drop is only present when the amp is too cold or too hot. When I point a fan at the amp the volume drops, when I remove the fan the volume rises to normal level until it gets too hot and starts to drop volume again. I point the fan on the amp again and the volume becomes louder until it gets too cold and drops and so on...
I hope someone is familiar with this problem in marshall amps, or knows which part of the amp could cause this problem. So the fluctuating volume as a result of a too low or too high temperature is the problem i'm dealing with. The volume drops are so bad, with volume at 9 o clock you can barely hear anything! Please help!
Thx for the effort, and have a kickass day
