Hey JP, thanks for the pep talk, but like I said, never made a living at repairing electronics, just dabbled in them, you might say, know enough to be dangerous You say the output is conducting, but I have no idea where or what would cause it. I have pulled each of the output trans and checked them, including the two new ones mj15003's that I installed and checked for shorts between the collector and emitter, and emitter to base, all check good.
I replaced the 761's with 2n5401's, and one other transistor. I have pulled one end of the 4003's from the board and checked each of them and all check good on my diode checker. I have pulled the end of the 22 ohm 2 watt and checked it as it is in parrell with the large choke and check as a direct short in circuit, it is good.
Checked each of the 250 ohm, 5 watt resistors, both check good. The 18 ohm resistors and the 4.7K ohm resistors are all good, found one 4.7 ohm resistor blown and replaced it with a 5.2 that I have.
Still have -19 volts on the speaker terms and the EP430 and 431 in the power supply area still get extremely hot as does the two 250 ohm 5 watt resistors. I have replaced the EP430 and 431 with TIP30c and TIP31c. Still have :
1K 5watt resistor .7volt one end, -23 volts on the other
2K 5 watt -1.7 volts one end 53 volts on the other
Junction of the 22 ohm and 4.7K 22.92
Base of 431 +15.92
Collector +23.08
Emitter 15.92
Base of 430 -15.38
Collector -25.15
Emitter -15.38
Sorry to bother you guys with all this, but that's where I'm at with it, kinda stumped.
Jim
Base of 431 +15.92
Collector +23.08
Emitter 15.92
Base of 430 -15.38
Collector -25.15
Emitter -15.38
Jim
