Amp sputtering question
  • Amp sputtering question
    I have a marshall plexi sytle tube amp that occasionally sputters and crackles. It happens with low frequncies notes and when you physically tap the amp with my fist. I pulled the phase inverter 12ax7 and the problem is still there when you tap the amp. I pulled the 2 power tubes (el34's) and the problem goes away. Would you say that the problem is located in the post-phase inverter/pre-output section? Oh, and its not the tubes as this problem has occured through many tubes changes.
    Thanks.
    My guesses:
    -Bad soldering job on the output tube pins.
    -Bad connection at socket.
    -Bias supply is acting up. (bad solder, bad cap).
    The fact that you can get the amp to act up at will is a tremendous advantage.
    I would start by monitoring things.
    -The B+ voltage. (Vdc & Vac)
    -The bias voltage. (Vdc & Vac)
    For a start.
    Once you narrow down where the problem is, then you can go about fixing it.
