Greetings from Russia
I bought a used Peavey C30 few months ago, and it seems to have some troubles in power section. One of power EL84's sometimes starts glowing brightly red, amp starts humming quite loud, while main signal gets really weak. When i just bought it, glowing appeared very rarely, one time a week approx., and since I didn't gig and had lots of other troubles, I didn't do anything with it. Just turned it off for some time when glowing appeared, and after a while it was OK.
But a month ago or so, amp started crackeling terribly, so I had to fix it, since it wasn't playable. Rsoldering tube sockets did the job. I thought I fixed glowing issue too, but it appeared again in a few days. Actually, it starts to appear more and more frequently, thus becoming very annoying. Also, if I'll decide to start gigging, that definitely have to be fixed.
I don't know where to start, because i'm not very good in tube schematics, and also, the problem appears unexpectedly, so I can't even measure anything, since I have to disassemble the amp first.
Oh, and just forgot to mention. I've tried tube swapping, and glowing stays within one socket, it doesn't depend on which tube is in that socket, so the tubes ain't the problem.
So could you give me some advice? I would really appreciate it
