I worked on a GK Backline 600 for a guy, tore into it and the 6 output transistors (Q21-Q26) were all fried. I replaced them, set the bias, and checked the 60V supply to make sure was correct, which it was. Tested the amp, not rigorously, but enough to know that it was working.
Got it back to him, he said he hit the Ground Lift switch saw a blue flash, and the amp went dead. I got it back, same situation, all 6 output trannys are toast. I've got the replacements, but before I pop them in, I want to make sure it doesn't happen again.
First of all, I can't see how the Ground Lift switch would cause anything to change in the circuit enough to cause the transistors to blow. That's got to be a coincidence, right? What else could cause those suckers to go? The 0.1 Ohm resistors aren't within the tolerance of my meter (I think it measures ~0.5 Ohm just across the leads), any recommendation on how to measure those accurately?
206-0240-B1.pdf
206-0181-B-B1-B2.pdf
206-0240-B1.pdf
