bad cat footswitch cable
  • bad cat footswitch cable
    Any of you guys ever fix/build one of these cables?
    They have an odd type plug on both ends, a 6 pin DIN with offset holes, not like a standard DIN, looks like an Amphenol, with the screw on ring to secure it to the jacks.
    Aside from fixing this cable, the guy wants me to make another, but I'm having a hard time trying to locate the plugs.
    Thanks.
    is it this type?
    we used a ton of these in an old job, whats the pinout look like?
    rjm music has some BC cables
    http://www.rjmmusic.com/store/produc...roductid=16148
      Yeah, I think I saw this (your?) pic in a Gear Page thread.
      RJM seems to be the only place I've found so far, thanks.
        if you show the pinout and maybe a few dia. measurements I am confident I could get you an exact replacement; this is not a custom piece!
          It looks to be an CPC/SPC Pro Signal connector (PSG01592) available at Farnell for 1.5 euros
          PSG01592 - PRO SIGNAL - SOCKET, MULTIPOLE, 6WAY | Farnell Ireland
          or CPC (?) for a bit less
          http://cpc.farnell.com/pro-signal/ps...red%20Products
          panel mount here:
          PSG01595 - PRO SIGNAL - PLUG, MULTIPOLE, PANEL, 6WAY | Farnell Ireland
          make sure the pins line up!
