I'm working on a Marshall 8040 Valvestate amp. I have a 10 ohm 1/2 watt resistor, R66 in the schematic, that is overheating and starting to burn if I leave it on. It is on Pin #5 of the TDA1514 IC on the line to the speaker. Rail voltages--+21 & -21 v look normal, as do the +12 & -12 v supplies. Any ideas of what is causing the resistor to over-heat? Here's a link to the schematic.....
http://www.drtube.com/schematics/marshall/8040-iss8.pdf
