Hi, I am trying to find the cause of loud popping in Marshall super lead 100 re issue , it's in the preamp and I have removed 1st two tubes . There is DC appearing on tone stack caps which can only be leaking through the board from other tracks . I have seem terrible cases of this in JCM 2000 amps , has anyone seem it in a Super Lead 100 ? thanks
Marshall Super Lead tracking on circuit board
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Luthin You View PostHi, I am trying to find the cause of loud popping in Marshall super lead 100 re issue , it's in the preamp and I have removed 1st two tubes . There is DC appearing on tone stack caps which can only be leaking through the board from other tracks
You should be measuring on the potentiometer side of the tone capacitors .
Otherwise you will just be measuring V2A pin 3 cathode voltage.Attached Files
HI Jazz P, yes I am reading up to 10Vdc on the pot side of caps , and as the 1st 2 tubes are not fitted , there is no DC on V2a cathode. I can see sharp static noises on CRO so I think its the board breaking down and leaking DC into tone stack .With V1 &2 fitted , there is also DC getting into the bright channel vol pot, and if you turn up the bright vol it biases the input to v2a , then if you turn it down the DC is shunted to ground and channel 1 can still work , it is not leaky caps as I disconnected them . I am surprised no one has seen this , surely I cant be the 1st ?
It is a leaky pc board , Marshall UK say they haven't seen it , but thats what it is , I removed the pate resistors and supply from the board and coupled the signal back in with caps , and the noise is gone , and so is the biasing problem with the bright vol pot . I see this as potentially worse than the TSL thermal runaway , because this amp isn't even warm and its unusable with popping .
