I have a Mackie 1202 that will only power up momentarily and+22 and CLP LEDs light up and then go off. Anyone have a schematic for the older microseries 1202? Does Mackie support discontinued documentation? THX
Mackie 1202
LOUD Technologies Inc. - Contact
You can beg them for schematics and parts, but it's been poor most of the time.
I have been very disappointed that the older products have very little or no support.
I have seen otherwise perfectly good mixers thrown away, for lack of parts.
And the customers have suffered a great deal, financially and otherwise.
Tested the voltage regulators on the daughter board and the mc7915CT (neg Voltage Reg) is only putting out -9V. Either the regulator is bad or something is loading down the -15V rail. Hope it's the 7915 because I don't want to pull the mother board.
Is there a resistor in series with the 7915 input? If so, measuer voltage drop to determine the current flowing through the regulator.
ANother test: is that regulator a lot hotter than the other one? If so, then we may be dragged down. If it is about the same, then the regulator itself is probably at fault.
Me, I'd slap in a new regulator at this point, as faster than those other things. And if it doesn't need it, at least the new one hasn;t been stressing.Education is what you're left with after you have forgotten what you have learned.
I can see why these small mixers get the air lock when broken. Of course the -15 voltage regulator is okay. Must be one of the many 9 pin SIP op amps - but wihich one? It looks like U1 and U2 are the first opamps off the -15V supply - what's the best way to hunt down the offending load on the -15V rail?
Originally posted by gbono View PostI can see why these small mixers get the air lock when broken. Of course the -15 voltage regulator is okay. Must be one of the many 9 pin SIP op amps - but wihich one? It looks like U1 and U2 are the first opamps off the -15V supply - what's the best way to hunt down the offending load on the -15V rail?
Replace the hot ones. A shorted op amp gets very hot, don't burn your fingie!
Also you can disconnect boards if possible, and see which board loads the power supply too much.
Also if you have a scope, check the output pin of the amp stage, it will have DC on it when the amp is bad, a lot of times.
OR take it to the air lock and space it.
OR take it out to 1000 feet and sink it.
OR it makes a great door stop.
I have a pretty nice Mackie mixer here, and there is no power transformer for it. And so, it's a paperweight. Lack of parts and support, again.
Actually, the 4560 has wider bandwidth & a higher slew rate than the 4558.
The drive capability is also higher.
They are not to be compared as apples to apples.
http://www.pikpower.com/new%20site/n...ae/ae04053.pdf
http://synthdiy.com/files/2006/NJM4558_ae04052.pdf
Originally posted by Jazz P Bass View PostActually, the 4560 has wider bandwidth & a higher slew rate than the 4558.
Oh yea, I forgot, your mixer will no longer pass 15 megahertz, my bad.
Originally posted by gbono View PostMmmm I'm more conerned about the 9 pin vs 8 pin compatability - V(-) is pin 4 on the 8 pin version and pin 5 on what's in this circuit. I think I might have found some uc4570HA at MCM that might work.
These are not popular anymore.
At any rate, pin 1 & pin 9 are both V+.
So I would imagine if push came to shove, you could 'start' at pin 2, continuing through pin 9.
That would be the same as a 'standard' SIP.Attached FilesLast edited by Jazz P Bass; 03-12-2012, 03:08 PM.
