Hi,
the volume drops out suddenly and no sound comes out of the amp anymore. Changing V1 (12AX7) helped each time.
The same thing happened 3 or 4 times now with several weeks in between these drop outs.
The tubes taken out measure OK on my tube tester.....
I did exchange the V2 socket (this was my first guess).
The heater for both V1 and V2 seems to by DC with both tubes wired in a row.
The heater to cathode voltage is bellow 25V at each cathode.
The only unusual thing is a 2.5-3V DC voltage at the grid 7 of V1. The voltage between 7 and 8 is -1,2V though. I guess it is somehow biased like a follower with the grid tied to a split R from cathode to ground. The stage amplifies normal.
The amp did never drop out in my workshop. Even if I mistreat the thing and beat it up....it never drops out. The rehearsal room the amp is normally in is quite cold I was told. Maybe a temperature problem ? But what kind of ?
Any ideas ?
Maybe someone had a similar problem with that amp ?
Thank you!
Tilman
Any ideas ?
Thank you!
Tilman
