I've had to repair many of these with channel switching problems. The 2 channel switching supply 470ohm dropping resistors tend to overheat and the solder joints go bad. I move these resistors to terminal strips mounted on one of the OT chassis bolts and add some thermal compound. Thought I'd share as this tends to permanently fix this issue.
Hot Rod Deluxe Channel Switching
